Publisher: Valve
As one part of our
game of the year 2007,
Half-Life 2: Episode Two set a new high in narrative and gameplay for the series. Using Valve's widely used, albeit not overly hardware intensive, Source engine that also features as a part of legendary games like
Counter-Strike, Team Fortress 2 and
Portal, we were keen to feature its performance here too.
The Source engine is the most scalable engine we test. While it still supports only DirectX 9.0, it features effects like dynamic lighting with HDR effects, motion blur, advanced Havok Physics and high model details.
Episode Two took
Half-Life outside into large open environments for the first time and we test with Gordon running through a large open level that combines forest and houses, with explosions and physics.
All in game detail settings are set to their highest levels, with HDR enabled, and for anti-aliasing MSAA was used where both settings were set from inside the game.
        ATI Radeon HD 4870 X2
        Nvidia GeForce GTX 280
        BFG Tech GeForce GTX 260 OCX Maxcore
        Nvidia GeForce GTX 260+
        Zotac GeForce GTX 260 AMP!
        ATI Radeon HD 4870 1GB
        ATI Radeon HD 4870 512MB
        ATI Radeon HD 3870 X2
        HIS Radeon HD 4850 IceQ 4 TurboX
        Powercolor Radeon HD 4850 PCS+
        ATI Radeon HD 4850
        Nvidia GeForce 9800 GTX+
        Nvidia GeForce 8800 GT
          50
          75
          100
          125
          150
          175
    Frames Per Second
        ATI Radeon HD 4850
          50
          75
          100
          125
          150
          175
    Frames Per Second
        ATI Radeon HD 4850
Frames Per Second
        ATI Radeon HD 4850
Frames Per Second
        ATI Radeon HD 4850
Frames Per Second
        ATI Radeon HD 4850
Frames Per Second
Even
Episode Two, which uses the Source engine from 2004, shows a significant benefit of over 11 percent once you get to 2,560 x 1,600 8xAA.  At lower resolutions and anti-aliasing settings, the performance differences are very small (less than five percent in all cases), so you're less likely to notice the improvements--especially considering the fact that the frame rates are very high to start with.
